Accu Force spring smasher and misc. parts
Accu Force spring smasher USB model (can be brought to the world 100 )
Gas carb 2 races since freshened by stealth
8- K&N 5" air filters (3 New ),3- air filter cans, car cover,16 volt battery charger, Beyea tri-y headers ( straight pattern ), used master cylinders, shifter, 2 hubs (1 front, 1- 8 bolt rear both used ), pinion plates,3- wheel spacers (3/8,1",2" ), weight clamps, used MSD's (old style all good ), grooving irons, multi siper (near new ), 2 new rf rocket tie rods, used 4-bar sets, steel drive shaft, numerous aeroquip lines and fittings (new and used ), 3- fuel logs (1 is a slider type near new ),fan spacers,oil filter adaptor for big filter,-20 thermostat neck, HTD drive hub (new), steering wheel, brake lines for a rocket,1 set of gauges (std ) , 1 set of extreme gauges with switches and tel tac ( both 4 guage panels). Plus more I'm sure, if you take it all I will deal but will sell in any form. Call or text 937-417-6720 leave a message will get back to you asap
