best motor combo for a two barrel class
The rules say the carb (4412) must be gauge legal so if that is a standard size ok...
I want to know what would be the best combonation Im also cosidering the rhs 14 degree heads.. Should I build it big 420 ci or smaller cause of the carb.... It is a wiered class full blown latemodel chassis spec tire 3 different motor packages and weight rules are 604 at 2300 lbs ...... 363 10-1 with any 750 carb 2400lbs... or any all steel with a gauge legal 4412 2 barrel at 2400....... let me know what you think would work the best thanks
