front bite numbers
does it make a difference in what you run for front bite numbers? is there a range you should be in?
We have been told before you want to try and get around 200lbs different with the left front being heavier then the right front.
what does this do? and how does it help over all performance on the car?
car is a 3000lbs camaro front clip 3 link rear pro stock.
Bite is left rear heavier than the right. period.
I used to run my car with my front weights even but that is only possible for me with about 120 bite so I dont end up there anymore.
what your car likes is what your car likes, ran it negative before and all the way up to 400 lbs. its nice to look at, but dont really mean a whole lot. I like it when mine is around 100 but really not concerned about it if everything else is where I want it.
