we have been struggeling some with are blue frontend rocket. if there is some bite in the track its great once it blows off and there is nothing to lean on its ok but not as good as are competitors.
cant seem to get it tight enough on entry and in the center off the gas. i think if i can get it better there the exit will fallow.
550 lr 375 rf
200 lr 225 rr
300 5th coil @ 36inch / 400 6th coil
120 wedge 9 1/4 j bar
54.5 left
55.5 rear
13 1/2 drop
integra ida shocks 3/8 low bank dusty slick track.
rr wheel base is shortend 1/2 inch so wheel base is straight up.
we start with 4 links at lru 3rd, lrb 3rd, rru 3, rrb3 hole. heat race time we usually drop both bottom rods 1 hole. i have dropped rrb rod to bottom hole a couple times but still never seems to help a bunch and i have never dropped lrb rod to the bottom hole yet. i have raised the lru rod to the 4th hole with the short bracket and it hurt traction from center off. im looking at softening the 6th coil, and maybe riasing j bar to 9 3/4 i took some reb out of the rf and put 250 psi in the dummy shock. car was decent but not good.
