--------------------Sale pending THANK YOU 4M ---------------------------------------
Roush Yates 360 ASCS motor – excess of 700 hp and 590 ft/lb on torque, lightweight, weighing in at only 430 lbs complete minus air filter, Engler injection, CP pistons, Titanium valves, retainers and locks, Jesel rockers and lifters, Pankl rods, MSD promag Brodix ASCS CNC prepared and hand finished within the ASCS rules, KSE trick center flow water pump, Aviad 5 stage oil pump, Waterman fuel pump, and tuneup information, completely freshened - 0 laps -
Race Car and Parts for Sale:
2011 Triple XXX rolling chassis - 2 races old - Winters thermal coated rearend, fuel safe outlaw cell, outlaw brakes, new Keizer right rear beadlock rim with brand new Goodyear tire, new circle left rear inner beadlock with brand new Goodyear tire, Pro shocks, new nose wing and top wing - car is race ready minus seat and engine
Spare wheel and tires:
Left real weld outer beadlock 14” x 5” offset has 92/15/15 Hoosier D10 mounted, rim is good condition, tire is about 80%
Left rear circle inner beadlock 14” x5” offset has Goodyear 95/15/15 G100 tire mounted, rim is excellent condition, tire is 90%
Right rear circle outer beadlock 17”x 5” offset has Goodyear 105/17/15 G200 tire mounted, rim is excellent condition, tire is 70%
Right rear circle outer beadlock damage to outer beadlock ring in one spot, needs ring, 17” x 5” offset has Goodyear 105/17/15 G200 tire mounted, tire is 80%
Front circle rim 9” x 3” offset has Hoosier D12 mounted, rim is excellent condition, tire is 80%
Front circle rim 9” x 4” offset has Hoosier D12 mounted, rim is excellent condition, tire is 80%
Front circle rim 9” x 3” offset very good condition
Front real wheel 8” x 4” offset good condition
Rims and tires used for asphalt racing:
Right rear weld rim 17” x 4” offset outer beadlock has Hoosier asphalt tire mounted, rim is good cond, tire is good for practice
Right rear weld rim 17” x 6” offset outer beadlock has Hoosier asphalt tire mounted, rim is good cond., tire is good for practice
Left rear weld rim 14’ x 5” offset outer beadlock has Hoosier asphalt tire mounted, rim is fair cond., tire is good for practice
Left front circle rim 10” x 3” offset Hoosier asphalt tire mounted, rim is excellent cond., tire is fair
Right front circle rim 10” x 4” offset with Hoosier asphalt tire mounted, rim is excellent cond., tire is good for practice
Spare Parts:
Radius rods:
18 ½” - 2
19 “ - 4
21 “ - 7
21 ½ “ - 3
22 “ - 3
22 ½ “ - 5
23” - 5
23 ½” - 8
24” - 4
Tierods and Drag Links:
45 ¾” - 3
46 ¾” - 2
47” - 3
47 ¾” - 2
48 ¾” - 3
49 ¾” - 1
50” - 1
Heims:
Left Hand new aluminum - 2
Right Hand new aluminum -2
Left Hand new steel - 6
Right Hand new steel - 6
Left Hand new aluminum jam nuts - 10
Right Hand new aluminum jam nuts - 10
Left Hand used aluminum - 27
Right Hand used aluminum - 21
Left Hand used steel - 5
Right Hand used steel - 3
Torsion Bars: (all bars are 4 or less races old)
1000 - 8
1025 - 10
1050 - 5
Master Cylinders:
1 Wilwood brake master 1”
1 Tilton brake master 7/8”
Misc Parts:
1 new light weight brake pedal
1 new light weight gas pedal
2 new knee protectors
2 used torque tubes (straight)
2 used mag torque ball housings (chevy)
2 used aluminum torque ball housings (ford)
1 new Sanders ford aluminum drive yoke
1 used ford aluminum drive yoke
1 new Bishop aluminum/steel drive yoke (chevy)
1 used yoke (ford)
2 used rear torsion arms
1 rear shift cable
1 rear brake disc
1 rear super light brake caliper
1 homemade turnover bar for adjusting valves
7 brand new w links with straps
5 used rear wing trees
1 rear wing tree with aero tubing
7 top wing struts for repairing top wing
2 fuel filters - canister type
12 assorted braided hoses and ends ( aluminum)
14 pro shocks
2 aluminum radiators
4 used nose wings
2 top flight top wings ( one is dished, one is flat)
6 new side boards to repair nose wings
2 t style top wing mounts
8 new nose wing front tube uprights
4 nose wing rear mount bars
2 new clamp on nose wing mounts
1 new dashboard - aluminum
2 new side panels lower - aluminum
1 used floor pan
1 steel windshield screen
1 aluminum wheel wrench
1 left shorty knerf bar
8 k&n air filters with aluminum tops
1 set of chevy spread port stepped hooker headers
1 set of chevy spread port steeped Schoenfield headers
1 1 ½” heel riser - new
5 6-pin wheel centers
Bunch of assorted body panels
7 rear torsion stops
2 complete front axles
1 bare axle
1 Lee power steering pump
6 new combo left front steering arms
4 new right front steering arms
2 Pitman arms
6 front torsion arms
5 front torsion stops
2 front aluminum brake discs
1 front spindle
10 new steering box mounts
2 used steering box mounts
2 used front brake caliper mounts
27 assorted wheel spacers
2 left rear wheel nuts
2 right rear wheel nuts
1 new drag link Bulter tether strap
Call cell # 315-532-7249 Tom Bashford[/QUOTE]
