dirty white boy
New Division for 311 Speedway
2018 Rules
Pro602 Late Models
Chassis
1-Must follow Fastrak Rules
2-Chassis built prior to 2014
Body
2-8" Spoiler max
3-No 12" side braces
4-No Mirrors
5-All cars must start with body parts in place
Suspension
1-No super light hubs
2-No oil fill hubs
3-No Bump Stops
Rear End
1-No low-drag rear ends
2-No gun drilled axles
3-No light weight hubs
Transmission
1-Bert or Brinn permitted
2-No low-drag
3-No lightweight
Driveline
1-Steel, Aluminum, Carbon Fiber permitted
Shocks
1-Any oil or sealed gas shock
2-No Adjustable Gas Pressure
3-Spilt Valve Shock permitted
4-Steel or Aluminum
5-No Canister remote or externally adjustable permitted
6-One working shock per wheel, except left front rear shock ok.
Shock Claim Rule
1-$150.00 per shock, does not include hardware
Carburetor
1-Holley 650 CFM
2-1" spacer plate max
3-2 gasket max, (thin)
4-$500.00 Claim Rule
Engine
1-602 GM, must meet all factory specs.
2-Engine must be factory sealed or sealed by a certified builder
3-All accessories must be front mounted, (power steering pump and fuel pump)
4-$3,500.00 Claim Rule on Engine, doesn't include accessories
Headers
1-No Tri-Ys
2-No stainless
3-Must use a economy header
4-No Beyea HEADERS allowed
5-$300.00 Claim Rule
Fuel
1-Pump Gas Only
2-No oxygenated fuels or oxygen producing additives added to fuel
Tires
1-FT-200/400
Weight
1-2,400 lbs after race
2-25 lbs for a full containment seat
3-25 lbs for a head or neck restraint
4-Using both weights breaks you must weigh 2,350 lbs after race
CLAIM RULES
Engine $3,500.00
Carburetor $500.00
Headers $300.00
Shock $150.00 per shock
Anytime a racer wins more than 3 races in a row, that racer has a choice of missing a week or moving up.
Look over these Rules, these Rules are intended to cut cost, 311 Speedway makes them along with Dr TJ Hicks, Michael Tesh and Fastrak. Thank you for racing 311 Speedway.
thoughts on these rules and any thing else that comes to mind???
