1 Attachment(s)
Lots of late model parts
Several Pierce/ Rayburn lowers. 18 and 19 RF and 16 5/8 LF Prices from 50.00 to 100.00 as shown. Pierce RF spindle 75.00
Several uppers, 10 3/4", 9 1/2", 9", 8 1/4" and 8". Standard New arms 15.00 used arms 10.00. Arms with ball joints add 5.00. Screw in 10 Degree uppers 20.00.
Several new and used swift springs in multiple rates and heights. 30.00 for used 45.00 for new. also have afco, blue coil and carrera used springs 5.00 each.
FSR double pass used.100.00
Several aluminum threaded big body Aluminum Carrera shocks. 9" and 7" in straight valve and split valve. 25.00 each coil kits 5.00 each.
1 set Rayburn purple Bert Smart tube spindles and hubs and rotors. 150.00. Spare smart tube hub and rotor 50.00
Tiger low drag rear with Bert smart tubes and hubs complete with Whers bearing chain limiters, PPM ball bearing birdcages, PPM brake brackets, PPM double sided Pinion mount, lift bar brackets and axles. 900.00
4 Gauge panel. 90.00
4 gauge panel and tach 175.00
RCI 22 gallon rectangle cell. 100.00
Wilwood Billet NDL calipers 50.00 each or 175.00 for all
Willwood Brake pedal assemblies with balance bar. 2 masters 150.00 single master 100.00.
Wilwood clutch pedal with master 60.00
Chevy steel Motor mts 10.00
Blaster coil and brkt. 20.00
Steering shaft with whers adjustable mt. 60.00
PPM Bearing birdcages. Has a bent ear on the bar side. 175.00 for both
Steel lift bars. used 40.00. new 50.00
Pierce Spindle. 75.00
If you don't see what your looking for I probably have it. I can send pics of anything you want. The more you Buy the more you save. Buyer pays shipping636 262 5707. Text for photos or I can email. fandscollision@aol.com
Still have a lot of this stuff. Can send pics. Will make package deals.
