Droop Limiting and Bumps.
So I have been away from here for a while. Had to eat my words about calling guys who run bumps on dirt crazy, because as I found out, running bumps on the RF in a dry slick greatly helps keep the car tight in the middle when transition handling would normally change from tight in to loose off due to the static cross weight setting. I did find out that contrary to what I thought running a lot less static bite on the slick, when running a bump was what was needed, not the other way around. Obvious blonde moment was me tuning crossweight for the amount it would decrease with the soft RF ride spring rate when weight transferred, and not the amount it would increase when it got onto the bump. Figured it out right away when I came in with a cold LF tire. Derp. Anyways I could go on and on, thing is, I was wrong and I have to say anyone that I argued with about bumps being stupid on dirt, I'm stupid lol. I was thinking now, (here we go again), with how stiff the RF and LR corners are becoming, due to bump devices and chassis hike like never before, the LF and RR corners begin to seem fairly soft, even if we are looking at the heavy RR spring setups. I have read somewhere that the tethers have been used in different types of racing to run the same springs on a car in a much more pre-loaded state in order to change the handling characteristics as well as responsiveness of the car. So aside from using the tether to actually help keep the LF down, this is just my brain kinda going off on a tangent here, do you think that using the tether setup on the LF (and RR, I suppose too) is one way of making sure these two corners are working at a rate that is functional with the increased wheel rates at the RF and LR corners we have been seeing over time? Is the RR tether just to keep the RR corner from coming off the spring like a LR? Or are guys actually pre-loading the living hell out of their springs these days? When I watch the WOO late models even on bumpy tracks it looks like the cars barely break their platform, like the car itself is actually really stiff lol. Anyways. Hopefully someone can come along and tell me I'm an idiot or I'm kinda on the right track. Thanks in advance.
