What would you say "in your opinion" is the best weight percents for a dry slick track in a 3000 lb hobby, pure / factory stock on a 1/4 mile, semi banked track ?
Rear % =
Left % =
Cross % =
Rear % =
Left % =
Cross % =
Depends on springs, shocks, weight placement; and most importantly driver feel and preference.
What only 1 answer...you guys must be pissed off racing season is over and are out deer hunting...bahabahbahbahabahaaaa
The general rule we tend to follow is 52% Left, 52% Rear, and keep the cross under 55%.
There's not a right answer for your question.
50.5 leftside---50 cross---58 rear.....even springs on the rear...super soft on rf..and extra heavy spring on lf for weight transfer.....outside tire pressures need to be 16-22 psi...lf 16psi--lr 8 psi so it can mash down smaller when load is applied....use same size tires on rear because even with low lr air pressure,,,when/if you spin them comming out then they will swell to the same o.d. pushing the car straight..
