602 crate oil pump noise ????
Brand new 602 crate, bought it new myself so Its never been fired up. Got it installed today, fluids in, everything hooked up. Dropped the oil primmer in and as soon as I started to spin the oil pump I could hear/feel this clicking/grinding noise. Pulled the primmer out and slowly turned the oil pump driveshaft with the long straight screwdriver. It only has BR-30 in it and the pump turns hard and you can hear and feel the pump making noise. Plus as soon as you stop turning it trys to reverse and turn back the other way on its own. Ran the pump slow with the primmer and with your hand on the bottom of the ol pan you can feel the grind/click.
This has to be raced as a 100% sealed motor so I can not pull the pan off it. Everything looks fine when looking down the dist shaft hole.
Thoughts? Ideas? Ever seen this problem? Thanke Eric
