has anyone tried them? seems like a good way to keep the tire planted flat?
I have a leaf super..the Po said he tried them but rubber worked better
A friend used them in a half leaf late model. Of course with a panhard bar, there's a lot of lateral movement. He felt it helped free some of the bind.
On a full leaf, because the spring is trying to twist, can change some of the effects. What works for one may be a curse for others.
When I raced leaf spring modifieds, I ran them when I ran composite leafs. They worked well in that application. I tried them with steel leafs but found rubber bushings to be much more consistent. Like 95Shaw said, it may work for one.
Seems the rubber bushing does well enough, ill put money elsewhere. thanks
