Bob Bolles/Magazine articles
So, I have been struggling with my car owner about a few things..mainly that he insists on reading articles in Circle Track and Stock Car Racing magazines that tend to contradict some of the "boots on the ground" advice and concepts found here. Granted, he lets me set up the car and has seen that what I have learned here and on Afco chassis adjustment sheets, Steve Smith's books, etc has worked and moved us towards a comfortable setup. But, sometimes our debates get somewhat heated because he reads the articles and interprets things his way, and I explain the physics and concepts behind the concepts I am learning, and gets pretty interesting.
Many of the articles he reads are written by Bob Bolles. Is he a four-bar guru or even a dirt guru?
A few examples of concepts we have discussed:
He has read that on banked tracks (above 12*), you need a stiffer RF spring than LF!!!! I have not once seen a DLM or a setup sheet that makes this recommendation, nor has anyone here ever made that suggestion. I even described that last year we started with a 500LF, 450RF and the car would NOT turn until we dropped to a 400 RF...
He has also read that it is imperative that the right side tires must be in line. Not just as a tool for squaring the rear end, but for proper handling. I am fully aware of the handling changes that occur from moving rear ends to the right and left. Bolles claims that if the RR is inside the car will push, and the car will be loose if the RR is outside, and that this should be tuned with wheel spacers. I explained that I have not yet seen one car on the track with RS tires in line..and have only seen one or two guys run a spacer, and that was on the left side!
I'm not looking for answers to these specific questions per se, but just want to know why the disconnect between printed material and boots on the ground sometimes!
