Trailing arm bushings ?
What kind of trailing arm bushings are the best to run on a 4 link metric car ? Do you want to run real soft ones or any kind of off set ones ? Also do you want the upper trailing arms that mount on top of the rear end higher on one side than the other ? Thanks for any help.
Do you run the mono balls on all the trailing arms ?
i run oem rubber, mono balls arent legal for my sanctions and my car works great
How much pinion angle are you guys running and how are your top trailing arms mounted ? (the ones on top of the rear end) I run on a tight 1/4 mile semi banked track that usually gets pretty dry slick.
