Ford IMCA Stock Car 4-Sale
The Hot Rod Lincoln – IMCA Stock Car
2004 Thunder Chassis
Crown Vic Frame shortened to fit Mark VII body
Car completely stripped down and updated in 2009
Aftermarket firewall and floorpan
Rearend rejigged w/adjustable control arms by JnJ Fab
Chassis powdercoated Chevron Blue
Afco front control arm bushings (Steel uppers L/W lowers)
Eibach front springs
16” Afcoil rear Springs
Pro WB Shocks "Have QA1 and Bilstein for extra $$"
Coleman 9” Floater rear end- 28 spline axles
28” PRC Triple Pass Radiator
Afco 2:1 Quick Steer
15 Gal. Fuel Cell
Longacre Gauges (OP/WT)
Wilwood Pedals and Master Cylinders with Brake Bias Gauges
Lajoie Full Containment Seat +1-1/2 Size
Impact Belts (1year old)
KRC aluminum P/S pump
MSD Ignition Box
Schoenfeld Headers coated by Trail
Driveshaft
10 Extra Wheels, 2 are beadlocks, 4.5" bolt pattern, 3" and 4" offset
7 Extra tires, 3 of them not mounted on wheels
2 Extra Eibach front springs
3 Extra Afcoil 16" rear springs
2 Extra Brake rotors for Coleman rearend
1 Extra 28 spline Axle for Coleman rearend
All extra suspension laying around the shop that will bolt on the car will go with it.
No engine, trans, or gear.
Best of Everything-Race Ready Roller
$5,000 for complete roller with spare car "1988 Mark VII" and spare parts
Have updated pics of car as of 10/28/10 available
Do you still have the ford imca car for sale?
Looking to get back into racing and looking for a good ford imca stock car. If it is sold have any info. where I might find one?
Quote:
MM90
15 Gal. Fuel Cell
MSD Ignition Box
Driveshaft
