Well the real heat of summer is almost here. Whats that one tip you could give to someone to help keep their motor cool during these long summer nights....
what does everyone use and what would be your one tip to help keep a car cool?
No one tip I have ever found...Just a well thought out system from one end to another...3 rows of tape on a 105* day and it runs 200* on gas...
Tip #1 Goto Stewarts Components and read their tips and frequently asked questions and live by them.
Tip #2 Use a kiddie pool and use it often!!!!!
Pull the radiator from the car and put it tubes up in the pool. Put a few drops of Dawn dish soap in the pool and fill it with water to cover the radiator. Leave it set over night and gently lift and lower the radiator a few times and leave it alone again. If the water gets to dirty change it. Rinse the radiator from rear to the front with a water hose until clean!!!! You will be amazed how much dirt will be in there!!!
(I know you said one but both are important)
I strongly agree on washing your radiator after every night.
I use a long rech, flex head water sprayer (the kind you use to water flowers and plants). I wash mine with hot water from the inside out, Top to bottom. The fine dirt just rolls out of the fins. On a 19x31 radiator I would guess I spend 4-5 minutes just washing the radiator clean. Eric
I haven't tried the pool method but I do take it out and wash it after every race. Some shrouds in front of the radiator have helped me. Funneling air into the radiator. They use to go straight out to the nose, now I have them angled out to the sides. So it grabs more air. So far so good.
GM 4 blade diesel fan. I've known many that believe a 6 blade sucks more air than a 4 blade.
Double pass radiator
1:1 pulleys
Good fan shroud
NO restrictors/thermostat
Tight belts
Speedway adjustable water pump
Gates flex hoses(Dayco hoses are junk)
500hp, 23*, all steel engine turning 8,000 rpm
100* south GA nite, engine runs 180*
We have a 3 gallon water tank mounted under the driver with a 3/8 fuel line run to it and its run all the was to the radiator and it hooked to a piece of pvc pipe with holes drilled into it and a electric fuel pump. When im under caution my car tried to run alittle warm and i could flip a swith and it pump water straight to my radiator. Cooled in down just fine lol
Thats illegal around me but when I took my pavement car to a dirt track on the Canada border in Washington state they all had those set ups.
I blew my real race motor so I put the 355 out of my 79 chevy with a rv cam in my car and borrowed a truck to tow up there. Qualified 2nd fast was in 2nd going back and forth for the lead and a lap car ran into me and broke a ball joint. All with a hydraulic cam flat top oem rebuilt motor with a 650 dp on top!!
The pool trick works clean mine once a month race three nights a week. Always run a big radiator and a 5/8 restriter hole in the thermosstate housing. Run some real junk motors and no holes in nose. Never come in hot.
We ran the setup just as he reccomends. A friend was over heating and was at the end of his rope and said to do waht I could, I set it up per stewarts and at practice at East Bay in July during the day with an on track air temp of 105 and the car only got to 210. At night that weekend we had to tape the grill to get it to 190. That was with the same motor and nose that ran HOT 250+ with a NEW tripple pass radiator and a lower hose restrictor. I put in a 3 year old single pass that was damaged slightly and removed the restrictor, built a basic shroud to pull air from the whole radiator and put panels in front to push air to the radiator.
Best 3 hours I ever spent, was to make like a air dam under the front bumper to the radiator. The sides went to the bumper and the top of the radiator sloped down along the bumper to the bottom. Never had anymore holes in the front bumper. Came off the track at 200. Stock water pump.
has anyone ever used one of the SBC cooling units to help get cooler water to the heads?
http://www.speedwaymotors.com/Small-...Unit,1856.html
go to washromm and take bath
I Run those extra cooling lines, but not like most do. I see many cars going from back on intake, up then forward then down into front of intake. I run them into a T into the water neck, so they never go back down. I don't like leaving an unventable high point.
Hope that made since.
yeah. speedway motors sells a kit that does exactly what you said.
we had a fan bolt break 2 weeks ago and it destroy out shroud and beat up the fan pretty good. we ordered a new afco fan...17 1/2"....and when we got it we noticed just by eye ballin' it that 2 of the blades were longer than the others. one side was 17 13/16ths and the other side was 17 5/8s. because of this the fan would not clear the rack. we ended up taking it to the grinder and making them both 17 1/2. has anyone ever noticed this or is it just us that has had this problem? it was an afco fan that was brand new out of the box.
