Does someone sell a 6th coil or what is the best way to make one. Im looking for 400lbs. What are different things people have tried.
steel or aluminum? what size of spring?
bsb makes one steel for a 5" spring that poske sells
or they make aluminum 2.5 id or a smaller one as well.
I was refering to the biscuit stye that I have seen people use because it is USRA Rules. And I believe you cannot use another spring so people are using biscuits.
http://www.brianruhlmanracing.com/sh...-15-07_014.jpg
We sell a polyurethane 6th coil unit with a 400lb/in rate. The entire unit sells for $169.99.
Give us a call and we can help you out with whatever you need for your mod or late model.
