need help to identify transmission
I just recently bought a mini stock 2.3. The shift lever was broke off where it has been welded on. I took out the 3 bolts securing the shift lever into the transmission and welded a new shift lever on. Now Im having an issue where the shifter is able to rotate. I dont think I have it lined up correctly but Im not sure. The guy I bought the car from said its a 2.14 transmission. There are 3 bolts securing the shift lever the trans. On the bottom side of the shift lever there is what appears to be an upside down U bolt and inside the transmission there is a small shaft. The shaft is at a slight angle and Im not sure if this is normal. Does anyone know what type of transmission this is so I can do some research on it? Should the shaft in the transmission be at an angle or should it be straight? Is there something Im missing when installing the shifter back into the transmission?
