KOKOMO (IN) - Kokomo Klash info posted.
Kokomo Klash 15 presented by Allstar Performance Information
Pre-registration will be required for all divisions.
If you plan on racing this event you NEED TO REGISTER!
Registration will open at 7PM Eastern on September 27th.
Entries will be capped for the following divisions at the numbers listed below.
Friday Night
60 Thunder Cars
Saturday Night
40 Late Models
80 Modifieds
40 Sportsman
80 Street Stocks
60 Hornets
Friday Night 10/15
Pit Gates Open: 3PM
Grandstands Open: 4PM
Draw Closes/Drivers Meeting: 5:30PM
Group Time Trials: 6PM
Racing to follow
General Admission: $20
Pit Pass: $35 (all ages)
Sprint Cars, Midgets & Thunder Cars will hotlap/group qualify for heat race starting positions.
Thunder Cars will have to go through a quick tech before being allowed to draw.
Racesaver 305 Sprints will use their series format for the evening.
All Heats are 8 Lap
B Mains are 10 Laps
A Mains are 25 Laps
Raindate 10/21 If Needed
RaceCeivers REQUIRED in ALL divisions!
All drivers must be 14 years of age or older to race.
RACE TEAMS: Absolutely no saving of pit spots. You will be parked by track staff. If you want to be parked by someone, you must arrive at the same time
Saturday Night 10/16
Pit Gates Open: 11AM
Grandstands Open: 3PM
Draw Closes at 3PM
Drivers Meeting: 3:30PM
Group Time Trials: 4PM
Racing to follow
Late Models, Modifieds, Sportsman, Street Stocks & Hornets will hotlap/group qualify for heat race starting positions.
Sportsman & Street Stocks will have to go through a quick tech before being allowed to draw.
All Heats are 8 Lap
B Mains are 10 Laps
A Mains are 25 Laps
CLASS RULES
NON WING SPRINT CARS
Rules:
Hoosier Medium or Hoosier H15 on the Right Rear
Other 3 corners are open to any Hoosier Tire
AMB Transponders (red) will be used. Rental fee will be $10.00
Payout:
1. $2021.00
2. $1000.00
3. $700.00
4. $500.00
5. $400.00
6. $350.00
7. $300.00
8. $285.00
9. $275.00
10. $260.00
11. $255.00
12. $250.00
13. $240.00
14. $230.00
15. $225.00
16. $220.00
17. $215.00
18. $210.00
19. $205.00
20. $200.00
21. $200.00
22. $200.00
B-Main Non-Transfer: $50
USAC Regional MIDGETS
Rules:
National & D2 midgets are legal
Hoosier Tire mandatory on all four corners
$100.00 bonus to the highest finishing D2 legal car
Payout:
1. $1221.00
2. $600.00
3. $350.00
4. $300.00
5. $250.00
6. $215.00
7. $200.00
8. $175.00
9. $160.00
10. $150.00
11. $150.00
12. $150.00
13. $150.00
14. $150.00
15. $150.00
16. $150.00
17. $125.00
18. $125.00
19. $125.00
20. $125.00
21. $125.00
22. $125.00
B-Main Non-Transfer : $50.00
IMCA Indiana Racesaver SPRINT CARS
Rules:
Series Rules in effect
Payout:
1. $621.00
2. $350.00
3. $250.00
4. $225.00
5. $200.00
6. $195.00
7. $190.00
8. $185.00
9. $180.00
10. $175.00
11. $170.00
12. $165.00
13. $160.00
14. $150.00
15. $150.00
16. $150.00
17. $150.00
18. $150.00
19. $150.00
20. $150.00
21. $150.00
22. $150.00
THUNDER CARS
Rules:
DOT Tires Only (NO RACING TIRES)
Must run gauge legal 500 CFM 4412 Holley unaltered carburetor
Factory Stock Steel style OEM Body (no aluminum or fiberglass hoods or trunk lids or plastic fenders)
Aftermarket Nose & Bumper Covers allowed (no open tail sections, no partially opened tail sections, no added drilled holes in tail section. It must be completely closed.)
3200 LBS minimum weight
Must have OEM stock floor pan (non OEM stock floor pans must be steel, with 50 pounds mounted near floor pan)
Stock OEM Frames ONLY
Steel blocks & steel heads ONLY (headers allowed)
Aluminum intake must have 25 pounds mounted in front of the motor plate
No aftermarket racing transmissions allowed (Bert, Brinn, Falcon)
No direct drives
Chevrolet engines will be permitted a maximum displacement of 360.4 c.i.d.
Ford engines will be permitted a maximum displacement of 362 c.i.d.
360 Chrysler engines will be permitted a maximum displacement of 367 c.i.d.
Top 5 finishers may have engines pumped
Maximum 8 inch wheel width
Stock Rear Suspension Only (Aftermarket Shocks, Springs & Ford 9 inch rear ends allowed in stock OEM mounting location)
Rear Weight Jacks are allowed (no front weight jacks)
Front Shocks must be mounted in OEM position
If a fabricated steel firewall is used 25lbs of weight must be evenly added to the outer edge of the left & right side of the front side of the firewall for a total of 50lbs. The car must weigh 3250lbs with a fabricated steel fire wall.
Maximum 4 inch spoiler allowed
Westhold Transponders (yellow) will be used. Rental fee will be $10.00
ALL cars MUST have a transponder pouch. This is MANDATORY!
Payout:
1. $421.00
2. $250.00
3. $200.00
4. $175.00
5. $150.00
6. $125.00
7. $110.00
8. $100.00
9. $90.00
10. $80.00
11. $80.00
12. $70.00
13. $60.00
14. $60.00
15. $60.00
16. $60.00
17. $60.00
18. $60.00
19. $60.00
20. $60.00
21. $60.00
22. $60.00
23. $60.00
24. $60.00
B-Main Non-Transfer: $35
LATE MODELS
Rules:
Open tire rule on all four corners
UMP Body Rules
Open Motors 2300 LBS minimum weight
Steel Block 2250 LBS minimum weight
Crate Motors 2200 LBS minimum weight
Payout:
1. $2021.00
2. $1000.00
3. $700.00
4. $500.00
5. $400.00
6. $350.00
7. $300.00
8. $285.00
9. $275.00
10. $260.00
11. $255.00
12. $250.00
13. $240.00
14. $230.00
15. $225.00
16. $220.00
17. $215.00
18. $210.00
19. $205.00
20. $200.00
21. $200.00
22. $200.00
Allstar Performance MODIFIEDS
Rules:
UMP & IMCA style cars are legal
Hoosier M30 & M60 tires are legal
IMCA G60 tire legal
Payout
1. $1122.00
2. $600.00
3. $400.00
4. $350.00
5. $325.00
6. $300.00
7. $275.00
8. $265.00
9. $260.00
10. $250.00
11. $235.00
12. $230.00
13. $225.00
14. $220.00
15. $215.00
16. $210.00
17. $210.00
18. $210.00
19. $210.00
20. $210.00
21. $210.00
22. $210.00
23. $210.00
24. $210.00
SPORTSMAN
Rules:
Open Tire Rule
Indiana Super Stock Style Body Rules
2800 LBS minimum weight
Stock Front Clip Cars ONLY (No all tube cars)
NO ALUMINUM BLOCKS OR HEADS ALLOWED
Maximum engine set back is 4" from the #1 spark plug to the middle of the ball joint
Maximum 10 inch wheel width.
Maximum tire tread width is 10 inch. (Foot print measured from outside edge to outside edge). -
No shaving/edging of tires to obtain 10 inch tread width.
Michigan Dirt Pro Stocks aftermarket front subs are legal
Payout:
1. $821.00
2. $400.00
3. $300.00
4. $250.00
5. $225.00
6. $200.00
7. $175.00
8. $165.00
9. $160.00
10. $150.00
11. $135.00
12. $130.00
13. $125.00
14. $120.00
15. $115.00
16. $110.00
17. $110.00
18. $110.00
19. $110.00
20. $110.00
21. $110.00
22. $110.00
B-Main Non-Transfer: $40
Allstar Performance STREET STOCKS
Rules:
Stock appearing bodies only (aftermarket five star style allowed)
Minimum roof height 50 inches & Maximum roof height 56 inches at highest point.
Maximum Roof Rake front to rear is 3 inches
3000 LBS minimum weight
Stock OEM frames (uni-body cars allowed) (Rear frame may be replaced from rear shock mounts back)
Maximum Engine set back is #1 spark plug aligned with the center of the upper ball joint
No aluminum blocks or heads allowed
Maximum 8 inch spoiler allowed
Weight jacks allowed
Rear Bumper covers or Filler Panels must cover the entire width of the car. (No open or partially open rear ends)
Payout
1. $721.00
2. $375.00
3. $275.00
4. $250.00
5. $225.00
6. $215.00
7. $205.00
8. $195.00
9. $185.00
10. $175.00
11. $170.00
12. $165.00
13. $155.00
14. $145.00
15. $135.00
16. $135.00
17. $135.00
18. $135.00
19. $135.00
20. $135.00
21. $135.00
22. $135.00
23. $135.00
24. $135.00
HORNETS
Rules:
Open to any FWD or RWD 4 Cylinder car
OEM frame & chassis only
OEM steel & plastic bodies (aftermarket bumper covers ok) full fabricated bodies are not legal
No aluminum bodies
Trunks lids/hatch must be on the car, no open rear ends
No spoilers
DOT tires only (no racing tires)
Headers OK
Hartford Speedway Cyber Stocks (4 & 6 Cylinder) are legal
Payout:
1. $421.00
2. $200.00
3. $150.00
4. $125.00
5. $115.00
6. $110.00
7. $100.00
8. $90.00
9. $80.00
10. $70.00
11. $70.00
12. $60.00
13. $50.00
14. $50.00
15. $50.00
16. $50.00
17. $50.00
18. $50.00
19. $50.00
20. $50.00
21. $50.00
22. $50.00
23. $50.00
24. $50.00
B-Main Non-Transfer: $30
