Shock recommendations...???
OK, I am probably going to open a can of worms here, but I am lost and need advice. I am stepping into a '09 Mars/MasterSbilt S7 Smack as my very first DLM experience after many years of modifieds. This is a VERY tight budget "Poor Boy" operation, so I cannot afford a $4000.00 set of canister shocks. I really not sure I can even afford the Afco double adjustables, and I am really leery about buying "used" shocks from an unknown source. The Mars setup book I received from the previous owner has absolutely no mention at all about what shocks and/or rates recommended for each corner. I have searched all over this forum, and others, but cannot find anything...? I even attended the big El Paso NDRL race this past weekend and asked several teams, but of course they ain't sayin... ;) so somebody please give me a clue where to start...? I will be primarily on a 1/4 mile semi banked "paper clip", long straights with short tight corners, stop and go. I have an all steel wet sump 406 motor and falcon trans. The dirt doesn't have very much clay in it... kind of a dusty sandy texture. I will start with the Mars recommended 500 l/f, 450 r/f, 250 l/r and 225 r/r. What compression and rebound ratios should I start with at each corner...? I know, this is a loaded question...? Can you get me in the ballpark...? Thanks, Jim
