Whats the best head gasket to use? Brand and part # please I am running a steel block with aluminum heads, 3.47 crank, 6"rods, 2 valve relief flattops
What bore?
4.030 is the bore size
Fel-Pro 1003 is what I would use.
I would use a mls gasket such as the 1142.
FP1043 will give you more compression with that bore
The MLS gaskets work great AS LONG AS THE BLOCK IS SMOOTH! LOL That block I got burnt on last year wouldn't seal with them. Used the SuperSeal from Mr.Gasket. Stuck like glue! Too bad for the hidden crack beside the cam!
Oh and I found your door!
A Long-Awaited Update for This Compact Crossover 2018 Volvo XC60 https://drive-v.com/wp-content/uploa...volvo-xc60.jpg 2017 Honda Civic Type R Jaguar I-Pace Concept and more
MLS is what I bought, had a Fel Pro 1003 like above on it and it worked ok.
