Ohlins, Genesis, & Afco Shocks For Sale + Parts
Shocks
Set of 4 Ohlins LMJ Canister Late Model Shocks Valved by RE Suspension $2,000
2 Ohlins STJ Compression adjustable LRF $300 a piece
2 Integra Big Bleed LRF $250 a piece
1 Integra Ultimate LRF $300
Full Set Genesis G3 Series (4 corners, Compression Adj LRF, 3-8 5th) $1,500
Full Set of Afco M2's (4 corners, Traction LRF, 2 5th Single Adj 1 Gas, 1 Oil) $1,500
Parts
2 18" High Pitch Cooling Fans $15 each
3 17 1/2" High Pitch Cooling Fan $15 each
1 38 1/2" Carbon Fiber Wiles drive shaft w 8" yoke
1 38 1/2" Aluminum Wiles drive shaft
HKG Racing Products Rocket Bearing Birdcages (TWM Copy) $450
Wilwood Pedals w/ Master Cylinders $125
Sets of Black Front End Copy Spindles $50
Used Impact Belts $50
37 1/2" Driveshaft for ballspline trans $50
32 Gal Fuel Cell w/ Cage on move-able weight clamps $150
Kirky Seat $75
Radius Rods (8 Total) $30
90/10 Pro Shock $40
J-Bar $50
Aluminum Slider Frame Mount $75
Springs $20 a piece or all 17 for $300
7" 400
8" 400, 750
10" 300 (2), 350, 425, 550
12" 175 (2), 200 (2), 225, 275, 325, 425
14" 185
