Ford Racing Engines and Parts
1- 9.2 deck SVO block 380 cid Ford short block, 4.125 bore, 3.5 Bryant crank, internal balanced, custon built Diamond domed pistons for AFR heads, 6.125 I beam rods low hours never hurt, short block only $2,000
1- 410 Windsor complete engine Eagle 4in crank, 4340 internal bal, Eagle 6.250 H-beam rods, .040 SRP pistons, Schneider custom roller cam, Brodix Track 1 CNCed heads Stud girdle, Comp Cams rockers, Super Victor intake, Canton pan, Ford Motorsports Aluminum valve covers, Milodon water pump. This engine has been raced off and on for 3 years and has been my 'loaner' engine to my good customers, it is very reliable and makes great power! $4,250
1-complete 416 Windsor 4inch stroke cast steel crank .060 bore 6.200 Hbeam rods, forged flatop Probe pistons, Kevko pan, Comp solid flat tappet cam, C-9 ported and polished heads (very nice) 7/16ths studs Scorpion rockers, Offenhauser intake, This is a fresh engine, never ran, balanced and assembled complete with 164 tooth flexplate and Balancer 28oz. $2,200
Will trade in 351w block cores@ $200 a piece! and any other interesting Ford 'stuff'!
1-347 short block with pan .030 stock block with main girdle, SRP domed pistons Eagle I-beams 4340 Scat crank, 5 nites in a mod $2,000 solid roller cam and lifters in this engine..Bullet, light weight balancer will throw in a Parker Funnel Web intake.
More stuff coming in soon, and will have couple cars for sale also (Fords of course) Will be looking for a set of IMCA Brodix Spec heads for Ford.
1-DUI distributor 302 Bronze gear complete $200
1-DUI distributor 351w iron gear complete $200
Having decided to go Late Model racing next season the modified stuff will have to go,
**Still for sale**416w (my personal car engine) .060 domed Icon pistons, Eagle internal balance 4" stoker crankshaft, 6.200 Eagle H-beam rods, Crower roller cam, Eldebrock Victor heads 210 runners (Aluminum) Scorpion rockers with girdle, Super Victor intake, Kevko pan, Milodon water pump Aluminum Valve covers/ with breathers. This engine is complete and ready to go with your distributor,it has less than 10 races on it since new and my driver said it was the most power he has had. He has raced my engines and Fords for 25 years+ Will sell for $4,000
Complete set of Yella Terra twin shaft rockers for small block Ford 1.6 ratio $300
good used set of PBM MAHLE .030 FLATOP FORGED PISTONS FOR A 408W one is new, 1.300 comp hgt. $200
Brand new SRP forged domed 347 pistons .030 in the box $475
Feel free to make reasonable offers on any of my engines.......
Call 563-452-3547 begin_of_the_skype_highlighting 563-452-3547 end_of_the_skype_highlighting weekdays 8-5 If its for a Ford, I might have it!!!
Thanks, Brian Gade
gaderacing3497@netins.net
www.emilygade.com
