I was just checkin out the sliders on my car and i noticed that one of them had alot of slop in it. Just wondering if it is okay to run them like this? It goes in and out like butter but just has slop when you rotate it.
The BSB slider is real easy to rebuild. I'd suggest taking it apart to determine what parts you need then give BSB a call and order them. While you have them on the phone you can ask for any tech questions you might have. http://www.bsb-mfg.com/
Are there instuctions on how to rebuild them I took the snap ring out and I could not get the shaft out ?
If rules permit, I would build a dummy shock and use that instead of that binder. most places are ok with it, they may ask you to take it off if u win a race to make sure its a dummy
They are easy to rebuild. BSB recommends that you take them apart every 4 races and clean/lube them.
