TheJet-09
Huh. Assuming lower control arms are the same length as the old, and center to center of their mounting points is the same as the old, and the same length LF tie-rod, you'd end up with a shorter RF tie-rod than before (with a wider rack).
What about spacers between the tie-rods and spindles? I think the RF called for a 0.500" before. And if they raised the cross member even more, I would think you'd need different ends on the rack. Maybe it was raised very little?
I'd measure your center to center on the lower control arm mounting points, just to be sure. I think they are/used to be 17 5/8" with the 18 1/4" rack (or real close, maybe 17 7/8", but definitely less). I can measure my 2014 Gen-X tomorrow, for curiosity if nothing else.
