Im thinking of going this route in my imca mod but got a few questions.
Can you run alky or is gas better?
who makes the best gas carb?
will a msd ignition work or is it better to go with hei set up?
also who makes good headers for these?
Braswell alky carb., MSD, Schoenfeld headers.
so they can be ran on alky
The can, as all internal combustion engine, be run on alcohol. The engine is not designed to be optimum on alcohol though. The compression and cam are not the best for alcohol. You can gain some torque though but your HP numbers are not going to do much.
I know a lot of guys are seeing significant gains with E-85. Obviously you have to have the right carb and you'll need to be careful to make sure you are REALLY getting E-85 or your could end up with some serious problems.
The E-85 should have been right with the Ratman on hp and better on torque if everything was right.
