What's the correct way to measure front ride heights on stock front clip chassis when measuring by ball joint. What's measurement for rf and lf? Thanks
Anybody??? Camaro clip, stock lowers tube uppers.
lower a arms LEVEL is a good start
That would be center of inner bolt to center of bj socket
Measure from center of A arm inner mount bolt to the ground. Measure from center of lower balljoint pivot ball to the ground (You have to figure out where that is and mark your A arm so you will be consistent with your measurements). You generally want the RF an 1/8th to 1/4 in higher outside to inner and the LF level to 1/8th lower outside to inner.
Dave
