If you have good side bite but loose drive off as night goes on will a stiffer rf spring help if you keep good side bite? I usually sofen the rf and loose all drive while on throttle, wondering if i could stiffen rf to gain drive off??
go with the stiffer rf and bump up rr 25
Softer is normally better in the slick. Try dropping right top bar 2 holes for more drive and/or right bottom for more side bite.(1/2" holes, 2 degrees apart)
