02 Masters Wide/combo car
RR on 3" BS wheel to add clearance for tire rub that is common on these cars.
Springs RF 350; RR 225; LR 200; LF 500
Weights: 55.1% Left, 52.3% Rear; 100 pounds bite
Bars in vanilla positions: 1 down both uppers; Lowers in top holes, short RRL;
5th coil 300, 2nd hole out.
406 engine steel block, 650-700 hp.
Car literally will not rotate. Turns in okay after I let off throttle. tap brakes, rear will NOT come around. Will stick to bottom or middle groove of corner but rear will not come around at all. By the time I get the throttle applied enough, it's too late and it feels like it just wants to snap loose like it's going to spin out. Video of the car literally looks like it is a pavement car, and one that pushes at that, as I can't get into the throttle soon enough. Then, once I get going, it buzzes the tires halfway down the straight. Was able to get car to rotate a bit with a hard stab of three wheel brakes, but it wouldn't hold for me to get it to work right.
Do I just have no idea how to drive? Is my low rear percentage that detrimental? Is the 3" BS wheel hurting me? Stiffer 5th coil?
1/3 mile moderately tight flat oval (Eriez Speedway, PA)
