I know that people run this what's the plus side of doing it? and do you use the steering linkages off the impala also or the metric?
I would also like a parts list and description of what has to be cut and welded to put impala parts in a g body need a chassis project for this winter
Ive never seen or heard of this. It was brought up on here before and went no place.
Personally how would you correct a g body front geometry if you had to use stock appearing parts ie. no tubulars?
i used camaro spindles and 80s crown vic upper a-frames on one, it worked great, used some upper a-frame mounts that are sold for asphalt the bolt went straight down into the block and slid in and out to adjust caster/camber
https://www.lefthanderchassis.com/v2...dgroup=2513594
I have impala spindles on my car with a 1/2 ton chevy up ball joint allstar #all56208 and used the #all56206 in the lower control arm. I had to get the upper control arm for the large bolt pattern and weld in a sleeve in the lower control arm to fit the lower ball joint. Also a plus for your roll center the spindles are 1 1/4" taller than a metric spindle and alot tougher. I would have to say it was well worth the time the car seems to turn alot better through the corners.
