IMCA late model....Parts sell out.....
IMCA Late Model Sell Out
All prices negotiable will package deal. Cash or credit card in person PayPal and shipping options also.
Call or text 815 541 3544
355 Ford IMCA spec engine 13 nights since fresh $5500
2006 MasterSbilt Smackdown Frame with most body panels no nose $500.....SOLD
SBF Brinn bellhousing no cracks or damage $275
Fast shafts aluminum drive shaft 39 with u-joints and 6 yoke $150
Reverse mount starter 8 nights old $125
Barnes 5 stage dry sump pump, Peterson tank, all lines coolers belts and Oberg and filter assy. $1000
IMCA SPEC carb spacer $50
Aluminum SBF Brinn Flywheel $250
Steel SBF Brinn Flywheel $75
AllStar Power steering pump $50
19 four blade GM style fan $20
REBCO wide five camber caster gauge $65
5.) GENESIS G3 double adj. shocks 4 nights since fresh from Genesis with dual stage kit and springs $2000
1.) Bilstein ASN LRF shock by speedway 7c 3r $100
6.) AFCO 13t series shocks Valved by speedway motors slick track set-up with dual stage kit and springs $750
Wehrs aluminum J-bar 18 Ύ adjustable both ways $75.......SOLD
Adjustable aluminum frame mount panhard angled bracket $50.....SOLD
PPM aluminum bearing birdcages newer bearings also comes with clevis shock mounts, and lock brackets. $350
PPM 4 links aluminum hex tubes with clearanced LRL bar with the good heims only 8 nights old $40......SOLD
AFCO style aluminum Clamp on Shock Bracket $25
HOWE clamp bracket for LR axle chain $10
MasterSbilt lift arm and support bar $50
MasterSbilt 6th coil $50
1 wide five wheel spacer $50
BRT 3.9 18 ½ with heavier style servo 10 nights since fresh from
Out-Pace $350
3.) 8 upper control arms bolt in style ball joints $10 ea.
2.) 10 ½ upper control arms bolt in style ball joints $10ea......SOLD
4.) 7 Ύ upper control arms bolt in style ball joints $10 ea.
1.) 8 Ό upper control arms bolt in style ball joint $10
1.) 8 ½ upper control arm bolt in style ball joint $10......SOLD
PPM RF and LF MasterSbilt S7 spindles $75 ea.......SOLD
TWM RF and LF MasterSbilt smackdown spindles $50 ea
RF MasterSbilt brand smackdown spindle $35
PPM GEN X RF lower control arm $65.....SOLD
PPM Smackdown 16 ½ LF lower control arm $65......SOLD
PPM Smackdown RF lower control arm 18 5/8 $65
Out-Pace Smackdown RF lower control arm 18 5/8 $50
Out-Pace Smackdown LF lower control arm 16 ½ $50
QA1 ball joints screw in style uppers and lowers with 2 extra 1 tall studs two uppers, two lowers and two extra 1 taller studs for roll center changes one for upper one for lower 4 nights old. $ 75
4.) Drilled and Scalloped Rotors 6.13 lbs only 4 nights old $100.......SOLD
4.) Wilwood superlite hubs and bearings $35 ea.
2.) Wilwood drive flanges Black and only 4 nights old $40
4.) MasterSbilt brand Aluminum 1 Ύ piston Brake Calipers $250
2.sets) Wilwood poly E pads only 4 nights old $50.......SOLD
TCI electric RF brake shut off valve only 4 nights old $50
Wilwood Brake pedal and clutch assembly with 1 masters for front and Rear smaller master for clutch also comes with bias adjuster. $200
2.) 6 Real beadlocks 12 IMCA style aluminum wheels $135ea.
2.) 5 beadlocks 12 older Real IMCA style aluminum wheels $120ea.
1.) 5 Duralite beadlock 12 IMCA style aluminum wheel $135
3.) 4 Real and Duralite beadlock 12 IMCA aluminum wheels $135
4.) 4 Real and Duralite NON beadlock wheels $100ea.
6.) HOOSIER IMCA late model tires only a few races old all 29s but one $35ea
Many springs and aluminum swedged tubes also
