Coil over spring length? and deck height?
Does the length of the coil spring make a noticable difference, if it does not bind? If so does a certain corner or the 5th arm make a bigger difference?
Example- In your setup sheet from builder a 12" 250lb spring is called for. You have a 14" 250 lb spring you just have to turn the adjuster up to make it work. The shock fit perfect the only difference is the adjuster on the shock had to be moved.
Also does the lower deck level around the driver in the newer late models give them more down force?
I hate if this is stupid just wondering.
