warriorautotech
Right now I am running Achilles 195/70/14 h-rated with 36 psi rf and 25 psi lf, all stock suspension,no sway bar, the changes I am planning are, Camber in the rf tire about 2-3 degrees, shim rf spring with 1" rubber spacer between coils, 1/4" toe out,40 psi rf tire, 20 psi lf tire.25 psi rears. The car is a 91 civic hatchback, 1900 lbs, mostly on the front, no added weight, I have been working on pitching the car high and sideways into the corner and driving out on the inside. The track is 1/4 mile around the outside, d-shaped, dirt, Turns 1&2 are fairly high banked and tight, 3&4 are not as high with the track flattening out toward the end of turn 4.
