I have a dw9. swing arm LR, two link RR. springs LF 500, RF 500, LR 350, RR 175. I HAVE 75 LBS IN LR (BITE). LB 23 BAR ANG. RR 7 BAR ANG. Do i need to run more LR bite in it to get it up on the LR more? if you guys can help me. i do thank you alot.
how much angle is in the lr bars. measure straight line center line with hiem joints. what shock is on the lr 5-3/6-3/8-2?
might stiffen the frontend up 650lf-700rf swingarm isnt roll dependant like 4-4 and needs something pushing back on it. How much lr drop does it have measuring in the area of where the ginger bread man is
gringer bread man??
yes on a swing arm car it requires more bite than that.i started out with about 100 lbs ended up with 250 before it got really good.hope that helps
