All NEW Parts, 1 annoying miss HELP
I'll try to keep this as short as possible. I've never had to chase a miss on a modified, so I am trying to figure out the cheapest way to figure out my issue:
Brand new 602 crate motor. New Carb, Ron's piston fuel pump, regulator, and msd rev box. I sent the new distributor to TRC and they wired up the rev box, locked it, and put a stronger coil in it.
I put a mark on the balancer for 32 degrees and lined that up to 0 on the timing pointer so it would start up close to what I was shooting for. Once I got it started, a buddy was running the timing light while I turned the distributor and held the throttle. My mistake was that I used the same color paint for 32 degrees and TDC on the balancer. We set the timing to 32 with the light off the 32 degree mark on the balancer and ran it for 15 minutes or so. The motor didn't sound how I wanted and there was a miss at idle. I could hold the timing light up to my hand and the flash would miss when the motor changed tone. Also, every once in awhile, the light would only come on for a couple seconds at a time, then off, then back on.
Shut it off and called TRC. We talked and I mentioned the 64 degrees. He said I could have blistered the plugs and need to change them out. I put a new set in AND changed the color of my marks on the balancer and it seemed to clear it up at idle. There was still a miss at 2500 to 3000 rpms. With the timing light the motor would read 0 on the pointer and 32 on my light, but every few revolutions the TDC mark would appear lower on the motor like at the 3 oclock position...then back to 0.
I worked on other things and just before heading to the track I wanted to check it out again. I started the motor and it sounded odd. Ran it for 2 minutes or so thinking it was really cold out. Still missing so I pulled the breather out and fuel was pouring out of the front vent tube. Tapped on the needle and seat and it finally quit. Motor sounded good, but now the miss was at idle again. Every few revolutions, 3 oclock again on the TDC mark. I lowered the bowls a little because I thought it was a little high.
Called TRC and they said clean the plugs real good or get another set. Clean the bowls out just in case hose dust got in there causing the needle not to seat. I did that all that and still has the miss. I'm going to change the distributor out tonight with a DUI setup.
It really seems electrical with the weird intermittent timing light flash for awhile, then the missing and TDC coming in at 3 oclock. I just don't know what to check and really can't afford to spend a bunch of money troubleshooting. Any ideas?
