Need forward bite bad
We run a 76 monte in street stock(hopped up class)we have a 250 rr spring 225 lr spring,52% left,52% rear,52% cross,car handles perfect just need more bite off the corner on a slick track,in the heat races its pretty good but as the nite goes on it gets less and less bite.would a softer (200)lr spring help.
Put the heavier spring on the left rear. Maybe tire pressure.
rear springs are backwards first off, you can either drop LR trailing arm, increase LR spring, stagger decreased on rear tires or increase bite(more LR than RR). Do one at a time...hope this helps!
Wouldn't more rear % help ? Maybe 54-56% rear ?
thanks guys we"ll give it a try.
