RR Ride Height...and Bite
With all my ride heights set correct the car has 150 pounds of bite. I can't back the coil over nut off any more on the LR, because it won't be touching the spring when the axle is hanging. So I put a few turns into the RR spring until my bite was at 100 pounds. Rechecked ride heights. Fronts are correct and RR is 3/4" higher than the what Warrior recommends. All my wheel weights look good and percentages are where I want them.
Is this anything to worry about? Am I cutting corners? Should I try moving mass in the car to get what I need? Generally speaking what have I changed "geometry wise" by raising my RR ride height?
