Matt49
The Steve Smith book you are referring to is great but it has some information that doesn't exactly conform with today's setups and this is probably the most glaring. The book says that a stiffer LR will make the car tighter on exit. This is based on old school understanding that as weight transfers to the rear and you apply the "heavy spring gets the weight" rule of thumb, the LR is going to get more load and hence drive harder causing the car to be tighter under acceleration. The problem with applying that logic to today's setups is that the LR spring is usually completely unseated once the car is at full hike and the car is only being held up by the bars. The spring isn't doing anything once it comes unseated. So the question now is is what the spring doing WHILE the car is hiking?
When you drive the car into the corner, a certain amount of weight is going to transfer from LR to RR and that number is completely independent of springs and only really dependent on roll center and vertical center of gravity (assuming you enter the car into the corner the exact same every time which I'm sure we all do ;).
Let's us a hypothetical example for the sake of simple math. Let's say on our car the LR has 500 pounds of static weight and the RR has 500 pounds of static weight and that when we go into the corner 250 pounds transfers from LR to RR. If we had 250 pound springs across the back of the car, this would make the LR spring unload 1 inch and the RR spring compress 1 inch.
Take the same car and now put a 200 pound spring on the LR and reset your ride heights. For the same amount of weight transfer that LR spring now has to unload 1.25 inches. That extra unloading means extra hike which means more bar angle which means more LR thrust angle which means tighter on-throttle race car.
This is a crude example for the sake of simple math and the reality is even more extreme. There are plenty of fast 4-bar cars out there with LR spring rates down under 150 pounds.
