hypercoil coilover springs
10" 350, 375, 400x2, 425, 450x5, 500x2, 550x2, 575x2, 600x2, 650x2,
12" 225, 250x2, 275, 350x3, 375x2, 450x2, 600
14" 175, 200, 300x2, 400 hypercoils 15.00 each
integra 10" 425, 12" 250 15.00 each
afco part# PR1 progressive 5th coil springs X2 20.00 each
afco part #27005 takeup springs X3 brand new 25.00 each
A-1 racing coilover kits for bilstien have 7" and 9" 10.00 each
afco alum shocks
1- 1373 brand new 50.00
2- 1363 used 10.00 each
1-1393-5 used 25.00
1- 1179-1 20.00
PENSKE remote canister shock mount kits WEHRS MACHINE 2 sets 50.00 per set
17" kirkey set w/ black cover 60.00
OUTPACE tubes w/ heims 2-12" 20.00 each 1- 14" 20.00 1- new 14" 30.00
hex tubes w/ 5/8 alum heims 2-12" 15.00 each 3-15" 15.00 each black in color
3- new 20" hex tubes 3/4" gold in color 10.00 each
1- 5/8 round gold alum tube 22" 10.00
misc used 5/8 and 3/4 alum tubes w/ heims 10.00 each
3 used alum pinion plates 10.00 each
2- wehrs alum j bars 75.00 each
1- hand clutch 25.00
1- bert ballspline blue alum coupler NEW 75.00
SWARTZ AND MASTERSBILT mid plates 20.00 EACH FORD AND CHEV
JOE HUNT chev magneto w/ external coil spare caps and rotors 200.00
5" K&N washable filters 10.00 each
STOCK CAR PRODUCTS 4 stage oil pump fresh from SCP 613.00 to fix 475.00
BEYEA tri y ford headers 15 races old NOT COATED 500.00 masters, swartz, rayburn
WEGNER chev non tri y headers 100.00 masters, swartz, rayburn
WILWOOD 1 1/4 rotor w/ holes new 25.00, 1 new 3/8 rotor w/ holes 25.00
US BRAKE 1 1/4 rotors set of 4 new 75.00
Wilwood superlite caliper used 40.00
wilwood superlite caliper 1 race old needs helicoil for brakeline fitting 25.00
OUTLAW big calipers 2 with new set of hawk pads 150.00
outlaw small caliper 1 1/4 pucks for right front 50.00
WILWOOD brake pads
gator green part# 150-2391 2 boxes 30.00 each
polymatric 7420e 1 1/2 boxes 40.00 like new used 10.00
HAWK pads hb237 4 sets 30.00 each hb100m 4 sets 30.00 each small wilwood calipers
AUTOLITE plugs ar134, ar3933, ar3911 2.00 each
NGK r5673-9 2.00 ach
wide 5 8 bolt drive flanges 2 new 30.00 each 2 look like new but used 20.00 each
COLEMAN alum drive shafts 40"x 3 75.00 each 37 1/2" 75.00
WILES 37" steel drivershaft 50.00
WEHRS 1" alum wheel spacers new 75.00 each
1" alum carb spacers 30.00 each
WILLYS 750 alky carb 300.00
2- 750 alky carbs built by WEGNER AUTOMOTIVE REASEARCH 300.00 each
SWARTZ
front end parts spindels, uppers and lowers, alum non bearing birdcages, MAKE OFFER
2001 SWARTZ frame w/ body never bent many feature wins 350.00
1998 SWARTZ bare frame 250.00 straight
NO JUNK HERE ALL GOOD STUFF
located in chippewa falls, wi 54729
Dale White 715-579-9900
