Starter hanging on flexplate
It's a racing mini-starter, 6 races old. It's on a SBC.
I have a shim kit with the bendix shim and a shim between the block and starter. When I turned the motor over it sounded like it was grinding really bad and hung on the starter. When the motor fired off it sparked inside the bellhousing pretty good. I put a washer on the inside bolt between block and starter to angle it a little bit away from the flexplate. It's a $20-something speedway motors flexplate.
What ya'll think I need to do to fix it?
