Fuel/Ignition Issue. Looking for some ideas.
Heres the situation guys. We switched from alcohol to gas this year (VP113). Last week was our first week out and the car would stumble horrible off the corner and get somewhat better going down the shoots. But it was still lacking alot of power. I was thinking that it was loading up so we sent the carb out to KB this week and had it gone thru and rebuilt. We figured it was fixed but had the same problem when we went out for hot laps last night. We bumped the timing up to 35 and changed the cap and rotor. Ran the heat and the car "seemed" to be fixed and had great power. The timing seemed to be a little much, so we backed it down to 32 for the feature. During the feature the car would run fine as long as I was on the high side where it was smooth. But if I ran the bottom where there was some moisture and it was choppy the car would stumble again from middle off then run fine again down the shoots. Has anybody experienced anything like this? Fuel Pressure seems to be fine, around 6 at idle and 9-10 on the gas. We're thinking that maybe it's a problem with the pick in the distributor or a coil since when we changed the cap and rotor it seemed to have fixed it. Thanks for any and all help.
