joedoozer
I agree. Don't waste a year just working on someones car. You will want to be in the seat.
It really depends on how much you want to spend, and how much of the repair work you are going to do yourself. If you are going to do all the crash damage repair yourself and not hire anything out, then go with something that seems to be working in your area. Try and buy something you have seen run. I have been very happy with my older Warrior.
If you have a lot of money and plan on sending it to the builder to get updates, crash damaged fixed, and you are going to pay someone else to do all the "big" work. Then I would look for a used chassis from a builder close to you. For me it would have been Barry Wright.
There really is no right answer to your questions, just varying shades of grey. Tips for buying a used chassis.
1: Try and see it run, or buy a car you are familiar with
2: Look at the bumpers, door bars, shock mounts, radiator supports, any bracket for body braces. These will have been rewelded many times and repaired. This will give you an idea of the work and maintenance that is being done on the car.
3: Get the chassis number and call the builder. Make sure it is what the seller says it is. Also find out if it is a DOM or a Moly car. Because there are Moly cars out there.
4: Also ask the builder what the Jbar/4 link/Front end should look like. To verify that things haven't been changed by someone after a crash.
