SRXSRULE
Single pass (i like Northern Cooling radiators) GOOD fitting shroud, good fan 17-19" that fits the shroud perfect (dia, and depth). 1-1 pulleys, stewart stage 3 pump, nothing in the water outlet, and screen 5-6" in front of the radiator to block the mud. The screen needs to be big enough to flow good air but small engough to block the dirt. I like to use two layers of 1/4" screen off set. Then clean the radiator core out every week.
Two weeks ago it was 100* and dew points in the high 60's at the time of hot laps. Temp was still 85* at 10:30 after the feature. My motor was 190* after the feature. Eric
