I have a question about the coolant bypass line on a 602 crate. I currently do not run one and have been running 230 to 240. Can a moroso part number 63500 be drilled and tapped for this coolant bypass line or should I shop for another pump? Any other tips to keeping this thing cool? Currently run a double pass radiator, restrict or with a 1 inch hole, 4 blade fan, ducting in front of radiator, shroud, and 32 degrees of timing.
