Anyone know of anything that would cause the Pinion to leak grease besides the pinion seal? Changed the seal twice in the past 3 weeks and it still leaks!
Put some silicone on the bolt that holds the yoke on.
Its pooling up in the seal, leaking from the two rings around the pinion shaft!
when you pull the seal out is there a cover on the bearing or can you see throw it if you can see throw it you need to change it i had the problem with mine put some silcone on the washer and bolt it up
Make sure you are using the correct seal, they make them with the lip facing in and out depending on which way your seal installs.
