Dirt Late Model Garage Sale
SBF Top end off of Kuntz & co engine cnc brodix track 1 heads with matching super victor intake, jesel shaft mounted rockers, and aluminum sheetmetal valve covers with spring oilers in them. fresh ready to go.$3500.00
franklin quick change 33" 36" no bird cages or calipers everything else 6 shows on it since it was rebuilt it is a 4.11 aluminum angled j bar mount and rearend filler tank $750.00
9" floater rearend 60" huds rotors and has 1bird cage on it for four link (no third member) $300.00
32 gal fuel cell white with straps $125.00 jaz
26 gal fuel cell white with sraps jaz $200.00 ( new) put it in car then took it out.
GRT bearing bird cages (blue)with brake brakets $450.00--------(SOLD)--------
Brakefloater (lr) with rod $125.00
351 windsor block 4 bolt mains all 5 caps it has 6 laps on it broke a rod it chiped the bottom of the back two cly still in good shape just paid $1750.00 will sell as is for $600.00
Barnes 4 stage pump,kse fuel & powersteering with oval craft tank lines and breather $1250.00
swartz fifth arm brackets and 6th spring and bracket $175.00
quick car4 panel gauges needs a couple of new warning lights $125.00
new fuel line with new fuel filter with mounting bracket and return line also new $135.00
289 to 351 windsor jesel shaft mounted rockers (new in box) $350.00
new black domintor nose and sides $150.00
12" weld wheel beadlock with weld cover$150.00
12"beadlock $125.00
switch panel 2 off on switchs and 1 push botton $35.00
4 scallop rotors and wilwood calipers 6 races old with brake lines new performance friction brake pads on them$550.00 --------------sold----------------
2 new fuel jug holders for trailer $150.00
2 gas integra swing arm gas shocks,port city built them$350.00
lot of afco blue shocks also to many to list just get ahold of me if you need afco shocks and 88 springs and helper spring kits also
lots of late model wheels Real, Duralite & weld different pricing on them.
Bert ball spine 6 nites on it since rebuilt inside and tail shifter and rods $1100.00
quarter master chevy bellhousing lite weight with oil pump mount $ 500.00
39" coleman aluminum drive shaft and yoke $100.00
traction shock afco 2 of them $175.00 each both have been on car one heat race.
17" kirkey lite weight seat right side head rest purple pads $175.00-----------sold------------
MSD box (cheater box) 8000 chip turns 8500 with msd coil $300.00
2 afco master cly $60.00
2 new imca muffers $80.00
GRT ford engine mid plate $45.00
1 frame mount j bar angled $80.00------sold-------
oval craft power steering tank with steel braided line $85.00
setfab oil cooler $75.00
Thanks for looking! phone #816 237 9066 or shop #816 293 5700
