Camaro front clip, steering and suspension questions....
Hi guys!
Building a new car for next season, and used a donor car to build it. Turns out 90% of the stuff of the donor car is old, worn out, bent, or junk. We used the camaro clip off of it.
The spindles are a mess. I was told they were impala spindles, but I am not sure they are as they have an 11" rotor which have been redrilled to 5x5.
I ordered some new parts, none of which seem to fit the car. I ordered 70's camaro inner tie rods which have the bend in them...the ones on the car do not (Impala???) It has swedge tubes and gigantic bolts to mount the outer tie rods to the spindles, which they have drilled out that part of the spindle to mount the tie rod bolts. The wheel bearings I ordered have no taper to them, and the ones I took out of it are tapered. Are there multiple 74-81 camaro spindle/bearing/rotor combinations?
I need to straighten this car out, and be sure I get it all right. I've ordered new ball joints since they were all bent and trashed, and am on the hunt for spindles. I think I am just going to put everything to Camaro parts so I know what everything is....unless someone has some better advice.
Sorry I don't know more about this clips or interchangeability, I've never used a camaro clip in the past.
http://sphotos-a.xx.fbcdn.net/hphoto...27121946_n.jpg
