Planning on running a big show that allows pull offs but I only have 8" rims would they work on 8" rims and what problems could it cause if any
Yea you can run a 10 inch take-off on a 8 inch rim, You probably wont like the way it feels under you. If you can try to find some 8 inch take-offs and use them you will like those very well. If you can run a 10 inch wheel then your set....Just groove them up and needle them real good and they will work fine.
I live in NE Arkansas and unfortunately I run 5 on 4.75 or I have a set I could borrow
Run a 8 in. Asphalt pull off they are easier to mount and the tire wont roll over as bad
Same way we used to mount semi tires................
