Where's the best place to check your ride height and what are some good starting point for ride height
Ride Height is a generic term that means something different to everyone. Heights from frame to ground tell me absolutely nothing. Heights from lower A arm inner bolt to ground and center of outer balljoint to ground tell me what I need to know on the front end. And lower trailing arm angles on the rear is what I look for. Where is a good starting point? RF lower arm, center of lower ball joint ball 1/4-1/2 higher than the center of the inner pivot bolt on cross member. The LF should be level . Rear trailing arm angles? RR level or as close as you can get, and LR varies but I ran 7Deg down in back, up in front.
Dave
Thanks racer96m
Dave, how far from the housing is your LR trailing arm mounted? We are allowed one inch from stock and currently mounted at 3 inches from the housing on both trailing arms.
Thanks Dave
Dave when you say center of balljoint do you mean center of the stim or center of overall length of the balljoint from grease zerk to tip of stim, thanks in advance
the pivot center would be the center of the ball joint., google the stuff your asking about, there are pictures and diagrams and such all over the world wide web.
Thanks a ton!!
I'm confused...If the center of the RF ball joint pivot ball is higher than the lower a arm bolt and the left side is level--wouldn't the left side of the chassis be higher than the right (unless the RF tire was considerably taller than the left?)
Yes the RF tire is usually bigger than the LF, and it has more air pressure than the LF also. Quit worrying about where your chassis is and worry about where your suspension is set at . The point of all this is to get the lower arm to scribe a consistent arc. So the RF for example is gona move up, right? So at slightly above the center line it will scribe an arc upward and inward. If its set below the center line, as it moves up, its arc lengthens before it hits center and then moves inward. This is not what you want to achieve a consistent feel.
Dave
