Ford 2.3 Engine build Off $125,000 on the Line
We are proud to announce that we will be putting a Ford 2.3 Race Engine Contest together which will be featured in 3 major magazines.
We will pick 10 Builders and fund there builds with $7500 Dollars. Here are some of the rules
1. Must used Stock Block & Crank of your choice
2. Crank May not be lightened, and you may use any rod journal size you want.
3. You must use any Stock
Untouched Intake.
4. Valve Lift no greater than .500 lift ( No Roller Valve Train ) Over Size Valves ok
5. Carburetor will be a 4412. ( 500cfm ). Must pass No Go Testing.
6. Clutch must be stock appearing.
7. Rpm range for testing 5000 to 7600.
8. No Dry Sump Systems
Engine must be drop in ready upon Delivery. And testing will be done in car on a rolling Dyno. Elevation of Shop location 5125ft
WINNERS
$10,000 for Most HP
$ 10,000 for Most TQ
$ 50,000 for Best Overall Engine
2nd $25,000
3rd $20,000
4th $15,000
5th $10,000
6th $ 9,000
7th $ 8,000
8th $ 7,000
9th $ 6,000
10th $ 5,000
For all the details and a compleye list of Rules Email us at
Jerry125357@gmail.com
Builders will be pick 6 -1 -2014 In Person.
