New an Used Parts List
Cleaning house!
New and used parts for sale:
(8) new ar3933 plugs. $10
(8) new ar50 plugs. $10
(1) used 66282h-16 crower roller lifter set, .842 hi po, std. Block, doulble offset, sb2.2 heads. Used but very few laps. $150
(2) new lightweight steel spring retainer sets. Uses super 7 locks, 1.318 od, 1.078, .713 steps. New sets of 16. $25 each set
(1) new lightweight steel spring retainer set. Uses super 7 locks, 1.300: Od, 1.036, .737 steps. Net set of 16. $25
(1) new total seal custom gapless ring set , 8 cyl, 4.135 bore, 043, .043, 3mm rings. Custom-m-08. $75
(8) used manley pushrods, 9.100 3/8, .120. wall $20
(8) used cv products pushrods, 9.150 3/8. $20
(2) new rons black fuel pumps. $300 each
(1) new nrc 4 stage pro series dry sump pump , bert/brinn mount with fittings. $700
(1) new comp cams part #800-16, sbc, set of mechanical lifters with oil hole in face. $100
(1) new isky 202-h sbc solid lifter set. $100
(2) used comp cams 7.700 pushrod sets, .080 wall, part number 7963-16. $20
(1) new titanium retainer and new titanium lock set for 11/32 valves, bead groove. Must have .290 tip length or longer. New set of 16 retainers and 32 locks. 1.450 od, 1.125, .725 steps. $150
(1) used cv products lower crank pulley, part number 30208. Grooves worn but usable condition. $10
(1) new srp piston set, part number 231301, 4.000 bore, 1.560 ch, 3.48 stoke, 5.700 rod $350
(1) new manley lightweight wrist pins. Set of 8. .927, .125 wall, 2.500 long, chamfered ends. $75
(1) new ross wrist pins. Set of 8. Part number 927-01-25c. .927 .150 wall, 2.500 long, chamfered ends. $75
(1) new case of 12 quarts, amsoil dominator racing oil. 15w/50 $80
(1) new engine pro sbc timing chain set. $20
(3) used msd cap and rotor kits, part number 84335. These are scheduled take offs for maintance. No issues. $25 for all 3
(1) new msd cap and rotor kit. Part number would be 84335. These were removed from a new msd distributor. $20
(6) used callies compstar rods, 5.700 long, 2.100journal, .927 pin. Used set of 6. $100
(8) used callies compstar rods, 5.700 long, 2.000journal, .927 pin. Used set of 8. 2 rods may need replaced or resized. $100
(6) used ross pistons. Part number is 90456. 4.030 bore, 1.568 ch., 5.7 rod, 3.48 stroke. Used and a few peppered marks but usable. $50
(6) used ross pistons. Part number is 92456. 4.020 bore, 1.568 ch., 5.7 rod, 3.48 stroke. Used and a few peppered marks but usable. $50
(6) used ross pistons. Custom set. 4.030 bore, 1.568 ch., 5.7 rod, 3.48 stroke. Used and a few peppered marks but very usable. Can supply custom spec sheet to make 2 more. .043 rings and 3mm oil rings. $50
(1) used sbc valve cover set. Fabricated aluminum with 2 breather tubes on left side. Bolts included. $30
i want this stuff gone now!
Any reasonable offers will be accepted!
Buyer pays shipping!
Located in central pa.
Call or text 717-586-5332
All engine parts are SBC. Valve covers and Comp lifters sold! Thanks!
UPDATED LIST! Cleaning house! MAKE AN OFFER!
New and used SBC parts for sale:
